2003 Dodge Dakota Fan
130,000 MILES • 6 CYL • 2WD • AUTOMATIC
BREN15
The fan no longer works. Graually it stoped working with the slower speeds going first untill only the fastest speed worked. Now that does not work either.
Would it be the fan motor or a controller problem?
What sort of cost to fix?
Sep 13, 2008 at 11:49 AM
BLACKOP555
  • 10,386 POSTS
the blower motor is probably failing, i would check for voltage at each different power setting to see if its the motor or if its everything pre blower motor.
Sep 13, 2008 at 1:24 PM
