2003 Dodge Dakota Check Engine code P0441
104,000 MILES • V8 • 2WD • AUTOMATIC
JAZON
What can I do to fix the code P0441 ?
Thanks Jazon
May 9, 2010 at 2:35 AM
  • 110,248 POSTS
PO441 - Evaporative Emission Control System Incorrect Purge Flow
Chances are you have a leak in the EVAP system. Have you had anything done yet?
May 9, 2010 at 9:35 AM
JAZON
I have not done anything. So I should look for a leak? I do smell gas sometimes in my garage. Also the light is now off, for the second time ?!?
Thanks Jazon
May 17, 2010 at 3:21 PM
  • 110,248 POSTS
Chances are you will not see a leak but rather smell fumes from the system. What I would suggest at this point is to have the system fogged. Basically, they will pump fog into the system and where the leak is, the fog will come out to identify the leak.
Let me know what you find.
May 17, 2010 at 3:45 PM
