camshaft sensor
36,000 MILES • 6 CYL • 2WD • AUTOMATIC
JOEDEN1364
Where is the camshaft position sensor located?
Oct 9, 2009 at 4:59 PM
JDL
  • 16,098 POSTS
Welcome, 3.9L engine, should be in the distributor. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Oct 10, 2009 at 3:08 AM
TIFFLOVESJEFF
Where are the crankshaft position sensor and the camshaft position sensor located on my 1995 Dodge Dakota Automatic 6 cylinder?
Mar 4, 2019 at 3:26 AM (Merged)
CARADIODOC
  • 34,411 POSTS
Crank sensor is in the transmission bell housing right behind the right cylinder head. Cam sensor is in the distributor.
caradiodoc
VINCET TELLEZ
Engine Performance problem
2005 Dodge Dakota V8 Two Wheel Drive Automatic 51.991 miles
Where are these located at?
MADMIKE1735
  • 951 POSTS
cam sensor assuming its a 4.7 is on the passenger side of the engine, towards the front and top of the cylinder head.... crank sensor is also on the passenger side of the engine located just under the exaust manifold closest to the rear of the engine, just under a freeze plug...
