2003 Dodge Dakota
65,000 MILES • 6 CYL • 2WD • MANUAL
EVIE1228
The carpet of my vehicle keeps getting soaked on a regular basis- even when it has not rained. I think that it has to do with the evaporator drain hose. Where exactly is this located at and how do I get to it. I had a simliar problem on my other vehicle and was able to just clean this hose out and fix it. I'm stumpped. ??? Thanks!
Sep 12, 2010 at 11:02 AM
HMAC300
  • 48,601 POSTS
it should be on the passenger side or middle of the vehicle. Crawl under the truck and you'll see it sticking down and run a stiff wire up inseide and twirl it around. You'll get wet maybe but it should clean the hose out enough.
Sep 12, 2010 at 11:27 AM
