2003 Dodge Dakota
37,500 MILES • 6 CYL • 4WD • AUTOMATIC
KAWASAKI18
tried to start my truck this mourning and it will not turn over, not even a starter sound, battery is ok everything lights up, tried it in nuetral also - nothing, checked the starter fuse -- ok. could it be the starter relay ? where should i begin?
Apr 5, 2008 at 1:06 PM
MASTERTECHTIM
  • 4,750 POSTS
try tapping the starter motor. if it starts then its bad.
Apr 5, 2008 at 1:11 PM
KAWASAKI18
Found the problem!, after further inspection of the starter my eye caught a glims of bare wire next to the transmission, as it turns out a rock had damaged the wire connection to the transmission range sensor. Of the 5 wires one was completly disconnected and the others badly damaged, I hooked up the one and the truck fired right over, although I need a new wire connection to the tsr Ill be going to the junk yard soon as auto parts stores do not carry wire connectors for these.
Apr 6, 2008 at 8:58 AM
