2003 Dodge Dakota
108,000 MILES • 6 CYL • 2WD • AUTOMATIC
BOOK512
The passenger side floor gets wet when I run the a/c.
how do I fix this?
Jul 22, 2009 at 4:15 AM
  • 110,251 POSTS
IT sounds like the drain is plugged. Check under the hood on the firewall (passanger side) for the drain. It is a black rubber tube. Move it around to see if the clog is near the end. If it is, water will come pouring out. Also, that is usually where they clog.
Jul 23, 2009 at 2:35 PM
