2003 Dodge Dakota
88,000 MILES • 6 CYL • 2WD • MANUAL
DONNALECHT
Couple of weeks back, my engine light came on. I checked the "code"to find P-0455. Emission control leak and kinda ignored it. Now my truck is having starting problems. It starts cold with no problems, but I hear and "feel" a little thud,maybe like a little backfire? I think it comes from the back somewhere This happens every time within the first few moments I start the truck, just once.
Then if my truck is warm and I stop somewhere briefly it won't start. It seems like it will start fine, but just as it starts there seems to be no gas and it stalls. Hitting the gas pedal it doesn't rev or anything, like you've got no gas. At first I thought it might be bad gas or something so I walked to get some gas treatment put it in and it started so I thought it was fixed.(it just had enough time to cool down) Since then I've also given it a bottle of injector cleaner and been buying premium gas.Problem became a pattern and now I've figured out that I can't shut it off hot and expect it to start unless I give "something"enough time to cool off.
Dodge service dept here is closed Sat. and Im at work weekdays when they are open.
Jun 19, 2010 at 6:21 AM
  • 110,251 POSTS
WHen this happens, have you checked fuel pressure?
Jun 19, 2010 at 4:26 PM
