2003 Dodge Dakota
DAVID MARCHETERRE
Engine Mechanical problem
2003 Dodge Dakota 6 cyl Two Wheel Drive Automatic
Thank you for your quick reply. The engine size is a v-6 3.9
This truck will buck while under normal driving conditions. It will buck for a few miles and then stop and start up again after a few more miles. Some times it will buck when starting from a dead stop.
Thank you again in advance
David
Dec 2, 2009 at 7:49 AM
  • 110,251 POSTS
Has the check engine light come on? Have you checked fuel pump pressure or replaced the fuel filter?
Dec 4, 2009 at 1:06 AM
