2002 Dodge Dakota Whisling noice front tires
130 MILES • 6 CYL • 4WD • AUTOMATIC
JAIMEVENTURA
when i drive over 60 per hour, i hear a whisling noice, mostly on the passanger side, it seems to come from the wheals, but i'm not sure. I heard it only once from the left side. When i take my foot off the accelerator the noice disapears.
Any help would be appreciated.
Jan 11, 2010 at 8:18 AM
  • 110,246 POSTS
Does the sound change when you turn? Have you checked the brakes?
Jan 13, 2010 at 2:15 PM
JAIMEVENTURA
there is no noice when i turn, and the brakes seem fine. i changed them last summer (disck and pads) i heard once more this morning driving at 30k/h with the 4x4 engaged.
Jan 14, 2010 at 2:06 AM
  • 110,246 POSTS
The other things that could make the noise will be hub bearing, input bearing (front differential) output bearing (transfer case) Check for play.
Jan 14, 2010 at 2:36 AM
JAIMEVENTURA
i will check that, thank you very much
Jan 14, 2010 at 2:46 AM
  • 110,246 POSTS
Let me know what you find or if you have other questions. Thanks for using 2carpros.com.
Jan 14, 2010 at 7:56 AM
