2002 Dodge Dakota Where do I start
2002 DODGE DAKOTA
KBURKS60
Computer problem
2002 Dodge Dakota V8 Two Wheel Drive Automatic
Truck has been running great. stopped at redlight after 5 miles of running it shut off, no studdering, when I tried to restart, fuel pump kicked in, injectors worked and RPM went crazy but truck did not start...after 6 hours truck started and ran for 60 miles home, then shut off and began acting up again, sat overnight started just fine....someone said they think my computer is going out...someone else saids camshaft senor..where do I start?
Jun 18, 2010 at 7:29 AM
  • 110,244 POSTS
Before replacing parts, you need to do some checking because this can be caused by several different things. First, has the check engine light come on? Have you checked fuel pump pressure?
Jun 18, 2010 at 7:52 AM
