2002 Dodge Dakota Tail Light fuse is blowing
50,000 MILES • V8 • 2WD • AUTOMATIC
DAILY1965GTO
I noticed one day that my instrument cluster where the speedometer is and the lights for the window switches were not lighting up, and also my tail light were not working ( I actually was pulled over by highway patrol for the tail lights) so I went to auto zone to buy some fuses. I replaced the fuses and the interiors worked again and the tail lights worked. So I started to drive again and the fuse popped again so I went to another auto zone and I replaced the parking lights relay and a new 20 amp fuse. The lights again worked until I starting to drive again and the fuse blew again. I got home and replaced the 20 amp fuse and the lights worked again. I am wondering what is causing this and if accelerating is playing a part in this? This is my work truck and I really don't have the cash to take it somewhere, I hope somebody is able to help me out. Either way I thank you for your time for even just taking a look at my question.
Thank you
May 8, 2008 at 8:23 PM
2CARPRO JACK
  • 11,533 POSTS
check the bulbs and sockets front and rear (running lights) for any discolored connectors or melted plugs. Sounds like it has a short somewhere, does the truck have any trailer wiring? If so look there as well.Might even be a bad bulb, front or rear
May 9, 2008 at 1:04 AM
