Mine has went bad. Will not turn over. Just makes the ignition bell come on. How do you put this in? Can it be done at home?
Sep 9, 2008 at 3:51 AM
✓Experienced Mechanic
Hi:
I would recommend that you have someone who is qualified complete this task. If you are not trained with working with air bags, you could get yourself in trouble.
I would check battery and fuses
check battery terminals
clean and tighten
try and get a jump if start check charging system and alternator
