2002 Dodge Dakota Starter switch
2002 DODGE DAKOTA
55,000 MILES • V8 • 4WD • AUTOMATIC
BIOMED
Mine has went bad. Will not turn over. Just makes the ignition bell come on. How do you put this in? Can it be done at home?
Sep 9, 2008 at 3:51 AM
  • 110,241 POSTS
Hi:
I would recommend that you have someone who is qualified complete this task. If you are not trained with working with air bags, you could get yourself in trouble.
I would check battery and fuses
check battery terminals
clean and tighten
try and get a jump if start check charging system and alternator
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
May 19, 2017 at 6:35 AM
