1997 Dodge Dakota Starter ?
1997 DODGE DAKOTA
155,000 MILES • 6 CYL • 2WD • MANUAL
DAVIDSLOUNGE
Lately, it seems as though my starter may be failing. I turn the key and hear a click, to then try it again, and again, before it finally works. On occasion the truck starts, without a problem. So I suppose the battery (which is new within 2 yrs) is fine. I am still on the original clutch. Plus, a month ago my mechanic checked the starter, and told me that it's working fine.
So, is this sounding like a problem with the starter ? Or is it possible that there's a problem with the clutch, and I can't push the clutch down far enough to ignite the engine ?
Thanks for your answer.
Jan 30, 2008 at 3:32 AM
LEGITIMATE007
  • 5,121 POSTS
It sounds like your starter is failing even though it was checked two months ago its slowly gettin worse. but before you buy a new one or retest it. check all connections . corrosion or loose connections can cause the same problems.
Jan 30, 2008 at 4:15 AM
