2002 Dodge Dakota Power windows
76,000 MILES • V8 • 4WD • AUTOMATIC
CRACKER JACK
  • 8 POSTS
The power window button for the passenger side wouldn't roll the window down. However I could roll the passenger window down from driver side with the master button.Then ice froze on the window & when I tried to power it down something inside broke & now neither window will roll down. Do I need a new window motor or is it something else?
Thanks for your help.
Mar 5, 2009 at 12:36 PM
  • 110,248 POSTS
Hi:
have you checked the fuse?
Mar 6, 2009 at 4:54 AM
MATTEQUA
Its called the widow regulator. Ihave broke three with the ice issue. Not to bad to replace. Expensive from dealer. Don't try to fix the plastic or steel wire. Just replace. Got one on ebay new for around $80.
Mar 10, 2009 at 11:07 AM
