2002 Dodge Dakota Power Door Locks Not Working
85,000 MILES • 6 CYL • 2WD • AUTOMATIC
MARKEL71
2002 Dodge Dakota Quad Cab - Power door locks now working intermittently. First thing in AM, doors open with key fob. After getting to destination, have to hit button 4-5 times to get doors to unlock. Same result if I use inside unlock button. Then when try to lock, truck honks but no doors lock. Doors do lock at 15 mph. Need some advice.
May 28, 2010 at 5:20 AM
  • 110,248 POSTS
Have you ever replaced the battery in the fob?
Jun 4, 2010 at 4:01 AM
MARKEL71
Yes. The confusing thing is that it also works intermittently with the door lock button on the door. So it must be in the locking system itself but i can't figure out where.
Jun 4, 2010 at 5:49 AM
  • 110,248 POSTS
You have a short somewhere. I would remove the main switch on the driver's door and check the switch and wiring. At least that is where I would start.
Jun 4, 2010 at 6:38 AM
