2002 Dodge Dakota PCV Valve
26,000 MILES • 6 CYL • 2WD • AUTOMATIC
PSCHULTE
What exactly is a PCV Valve and what is its function and where is it located and can I change it myself??
Apr 9, 2009 at 7:18 AM
BLUELIGHTNIN6
  • 16,542 POSTS
PCV stands for Positive Crankcase Ventilation. The PCV valve (along with the Breather Element) recirculates unburned gases back into the engine to be reburned, cutting air pollution. A plugged PCV can cause rough engine idle and many other problems, including engine damage. PCV valve is normally attached to manifold. Removal and installation is fairly simple but I do not know your experience level so it is hard for me to answer the last question you have.
Thanks for using 2CarPros.com !
Apr 9, 2009 at 7:58 AM
