2002 Dodge Dakota oil pressure
112,000 MILES • 6 CYL • 2WD • AUTOMATIC
MWLINDSAY
I have no oil pressure, but oil level is full.
Could it be anything besides the oil pump?
Mar 12, 2009 at 2:59 AM
BLACKOP555
  • 10,386 POSTS
check the guage first, unthread teh oil pressure sending unit and check the pressure, is there any on the guage? if not theres a issue with the oil system, if it shows pressure then either the guage is bad or the sending unit. let me know what you find.
Mar 12, 2009 at 7:59 AM
MWLINDSAY
I have done more research on this issue. I recently added a product called ZMAX to my oil and the next day had oil pressure problems. Sounds like it stirred up sludge on the intake tube. How hard is it to remove the pan and clean it out?
Mar 12, 2009 at 9:43 AM
BLACKOP555
  • 10,386 POSTS
wouldnt take long at all, but that sludge could be in your engine now. you might need to have the block flushed out also. expensive.
Mar 13, 2009 at 7:19 AM
