2002 Dodge Dakota obd2 code po456
111,000 MILES • V8 • 4WD • AUTOMATIC
MYKERULESC
comes up as EVAP monitor leak (Small) detected
Where do I look for this and how do I fix?
Any help is appreciated, thank you.
Jan 13, 2009 at 10:32 PM
  • 110,251 POSTS
Hi:
The best way to find an EVAP leak is to have the system fogged. A mechanic will attach a for machine to the system and where ever the leak is, you will see the fog leaking out.
EVAP leaks are a pain to find. I recommend paying a few bucks to have this done; otherwise, you will most likely drive yourself crazy trying to find it.
Jan 15, 2009 at 3:28 PM
