2002 Dodge Dakota no fuel
55,000 MILES • V8 • 4WD • AUTOMATIC
TEXASSPORTMAN
My truck will not start. There is no pressure at the fuel rail. I have checked all fuse & relays, even replaced the fuel pump. There is spark but still nothing.
May 11, 2008 at 9:57 AM
  • 75,988 POSTS
Do you hear the fuel pump come On when key at run position-if so check the fuel pressure and then comeback with the pressure readings.
May 11, 2008 at 10:11 AM
