Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Dakota
Exterior Light
Headlight
REPLACE/REMOVE
2002 Dodge Dakota lights
2002 DODGE DAKOTA
123,000 MILES • V8 • 4WD • AUTOMATIC
MORISN23
MEMBER
1 POST
How do I change a headlight on the 2002 dakota?
Jan 11, 2009 at 3:35 AM
Experienced Mechanic
Hi:
The bulb is replaced from behind the headlight assembly. Open the hood and in the back of the assembly you will see where the bulb is plugged into the assembly. Turn it counterclockwise and it will come out.
Jan 12, 2009 at 2:47 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
