2002 Dodge Dakota HVAC
65,000 MILES • V8 • 2WD • AUTOMATIC
CROWND
MY 2020 dakota HVAC blower stays running when the key switch is off. If I don't manually turn off the HVAC blower at the panel rotory switch it will run the battery low. Also sometimes when I need to run the heater or A/C the blower will not turn-on. Could the problem be the resistor and not the blower assembly and if it is the resistor how do you access it?
Jun 1, 2010 at 6:28 AM
DOCFIXIT
  • 18,828 POSTS
Blower is powered up off run circuit of ignition switch for motor to run ign sw must have fault
Jun 1, 2010 at 6:52 AM
