2002 Dodge Dakota heater blower
MEX
Heater problem
2002 Dodge Dakota 6 cyl Four Wheel Drive Automatic 126k miles
the blower not blowing i checked the fuses ok. what i did find out is that i supplied a ground to the blower wire it worked. do you think the resister is bad ?
Jun 18, 2010 at 2:10 PM
  • 110,248 POSTS
Did all speeds work when you provided a ground?
Jun 18, 2010 at 2:27 PM
MEX
When i supplied the ground to the blower it went on high can't control the speed. I had a dodge truck before and the resistor went bad the blower went to high only. Knowing that i found out that the resistor was bad and replaced it.
Jun 19, 2010 at 3:18 AM
  • 110,248 POSTS
I think you have the same problem here.
Jun 19, 2010 at 4:22 PM
