2002 Dodge Dakota head gasket/ gas mileage
JEFFRINCK
Engine Mechanical problem
2002 Dodge Dakota V8 Four Wheel Drive Automatic
i just had a head gasket put on a 2002 dodge dakota and everything seems like it is fixed other then, my fuel mileage dropped from 18-20 mpg to 8-10. the shop is a dodge dealer and says everything is done right, my question is what could i look for that may have caused the gas mileage to drop so much right after a problem is fixed that should have made the mileage bad
Oct 20, 2008 at 2:34 AM
  • 110,246 POSTS
Hi:
That kind of change in mileage is serious. Look around for broken or disconnect vacuum hoses. Check the ignition timing and the O2 sensor. Also, you may want to take it to a nationally recognized auto parts store to have it scanned for codes. Most parts stores will do it for free.
Let me know what you find.
Oct 21, 2008 at 4:22 AM
JEFFRINCK
[quote:0a52bad9aa="Jacobandnickolas"]Hi:
Joe[/quote:0a52bad9aa]
Joe,
did a scan and found nothing other then the timing is advanced 4 deg and they said the computer set that and didnt know what is optimal. do you have any other suggestions? thanks for helping in the first place.
Oct 30, 2008 at 1:27 AM
  • 110,246 POSTS
Hi:
off the top of my head, the only thing I can think of is a sensor. Are all vacuum line connect?
It may be time to go to a dealer to have it checked, Thery have the scann tools needed.
Let me know ig you have any have other questions.
Oct 30, 2008 at 1:42 AM
