2002 Dodge Dakota Engine reving
130,000 MILES • V8 • 4WD • AUTOMATIC
CHINSY2000
  • 6 POSTS
Hi when starting the truck it will rev up and down up to about 1500rpms and when in gear with foot on brake will do the same but not as high up to a 1000rpms. Have change spark plugs last year and changed the air filter last week.
Jun 27, 2009 at 5:15 AM
  • 110,251 POSTS
Has the check engine light come on? It sounds like it could be an idle air control valve or a throttle position sensor. Also, have you checked for vacuum leaks? You should also remove the EGR valve and make sure it is working and not carboned to a point that it doesn't work.
LEt me know.
Jun 27, 2009 at 11:08 AM
