Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Dodge
Dakota
Drivetrain
Differential
Pinion Gear
2002 Dodge Dakota differential
2002 DODGE DAKOTA
125,000 MILES • V8 • 4WD • AUTOMATIC
DODGEBOY2002
MEMBER
1 POST
when replaceing the bearings in the rearend should there be a pinion gear shim kit installed also, (basically reshimming the pinion gear)
Dec 10, 2008 at 11:51 AM
Experienced Mechanic
Hi:
There doesn't need to be one unless there is excessive play in the pinion.
Dec 12, 2008 at 5:28 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
