2002 Dodge Dakota
CASTO
  • 2002 DODGE DAKOTA
2002 Dodge Dakota V8 Four Wheel Drive Automatic
how to take off a front drive shaft
Sunday, May 9th, 2010 AT 2:19 PM
  • 109,885 POSTS
REmove the two U-bolts from the front (universal Joint) and that section will come off. Be careful not to bang the joint because there are rollar bearings that will move around and cause problems putting it back together if the end caps come off.
At the rear of the drive shaft it is bolted to the output shaft from the transfer case. Unbolt it and the entire driveshaft will come off.
Sunday, May 9th, 2010 AT 4:32 PM
