2001 Dodge Dakota Vents
2001 DODGE DAKOTA
90,000 MILES • 4 CYL • 2WD • MANUAL
BRADWOMBLE
When I have my air on, the floor of my truck starts to shake. If it is on low, you can hardly tell there is shaking but when you put it on high than you can really tell. I need to know what is going on because it is rather annoying.
Feb 16, 2009 at 4:43 AM
  • 110,244 POSTS
Hi:
Is the shaking coming from the engine or the fan motor itself?
Feb 16, 2009 at 8:16 AM
BRADWOMBLE
I cannot tell, it just shakes on the floor board. I believe it is coming from the fan motor.
Feb 16, 2009 at 9:48 PM
  • 110,244 POSTS
Ifit's the motor, the bearing must be bad in it. Does it make any strange noises?
Feb 17, 2009 at 12:02 AM
BRADWOMBLE
Just the rumbling from the floor boards, thats it. Does the Bearing cost much, and can I do the fix myself?
Feb 17, 2009 at 6:43 PM
  • 110,244 POSTS
Hi:
Don't laugh but I want you to try something. Turn everything on that causes the vibration and place the car in park, with the park brake on. Look under the vehicle where you feel the noise. By any chance is the exhaust hitting the under side of the car? I know if seems crazy, but with the added pressure from the AC, it could happen.
Feb 18, 2009 at 5:42 AM
