2001 Dodge Dakota Truck stalling at stop and bucking while
150,000 MILES • V8 • 4WD • AUTOMATIC
JAWSD3
Truck had a vapor issue which was fixed after shop fogged it and replaced the TPS. Now the truck is stalling when it is stopped. When we drive it bucks as if it wants to stall. Shop said it could be the computer resetting itself but did not see any error codes. They cannot find resolve the issue. What could it be? Is the new TPS either bad or installed worng? As a note we ran higher octane gas and used Seafoam to clean the fuel system when it first started. Did not hurt or fix the issues. Problem persists when tank is full all the way down to 1/4. There does not seem to be any electrical issues.
Nov 11, 2009 at 4:49 AM
DOCFIXIT
  • 18,828 POSTS
Was fuel pressure tested?
Nov 11, 2009 at 5:14 AM
JAWSD3
The Repair shop said the fuel pressure was fine. I even asked about the fuel pump and they said it does not appear to be an issue.
Nov 11, 2009 at 2:23 PM
