Replaced Catalytic Converter because engine was stalling now it runs better but stalls when idling at stop signs
Saturday, December 20th, 2008 AT 5:52 AM
MECHANIC
Do you have a check engine light and when was the last tune-up?
Test the idle air control motor/throttle position sensor, also the PCV and EGR valves
SPONSORED LINKS
Saturday, December 20th, 2008 AT 6:32 AM
SOCIAFARMS
MEMBER
No sir There is no check engine light, and I have replaced the idle air control sensor already and it had a tune up before I replaced the catalytic converter
Saturday, December 20th, 2008 AT 7:32 AM
SOCIAFARMS
MEMBER
I was thinking that it could possibly be the emission sensor considering the catalytic converter went bad but I am just a woman not a mechanic
Saturday, December 20th, 2008 AT 7:33 AM
SOCIAFARMS
MEMBER
The gentlman that replaced my c converter said I may need new spark plugs because the converter was so bad. Put spark plugs in it myself about 2 weeks before replacing the catalytic converter
Saturday, December 20th, 2008 AT 7:35 AM
MECHANIC
I understand lets have the other stuffs checked out then come on back
