2001 Dodge Dakota Start Truck just get a click
RICH7432
Engine Mechanical problem
2001 Dodge Dakota V8 Four Wheel Drive 167000 miles
Battery on truck is brand new, now when I go to start truck I just get a loud click coming from the starter. Is starter bad? Or does it need something else?
Aug 25, 2009 at 11:38 AM
  • 110,248 POSTS
It sounds like a bad starter. Try this. have a helper turn the key to the start position while you check the smaller wire on the starter for voltage. You should have 12+ volts. If you do, remove the starter and have it bench tested at a parts store.
Let me know what you find.
Sep 9, 2009 at 3:34 PM
