2001 Dodge Dakota squealing
186,000 MILES • 6 CYL • 2WD • MANUAL
CMBASHAM1
My truck started squealing a few days ago when the clutch was pressed. Now it is squealing loudly all the time. Today the clutch seems a little harder to press. Is this a major emergency for repair or can it make the 250 mile drive home this weekend. I am trading it in for a new car on Saturday and don't want to put extra money into it.
Apr 21, 2010 at 1:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello and thanks for donating
Unfortunately, a squealing sound that occurs when the clutch is depressed and held is usually caused by a bad pilot baering or bushing. Does the noise seem to go away as you release the clutch?
Apr 21, 2010 at 1:46 PM
CMBASHAM1
today the truck is squealing for a short time after depressing the clutch.
Apr 21, 2010 at 1:52 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Usually squealing associated with a clutch fault only happens during depressing or releasing the clutch pedal. Your squealing may just be a drive belt. May also want to check your fluids (brake, clutch etc..)
Apr 21, 2010 at 1:56 PM
CMBASHAM1
my son says that the noise does go away after releasing the clutch. Do you think it will be ok to make the 300 mile drive home. we are getting rid of truck this weekend.
Apr 21, 2010 at 2:05 PM
BLUELIGHTNIN6
  • 16,542 POSTS
i would hate to say that it could or couldn't make it a certain distance but if it just started this squealing than most likely it will last for quite a while longer, i personally wouldn't be worried to drive it 300 miles in this condition, just my opinion though .
Apr 21, 2010 at 2:11 PM
