2001 Dodge Dakota RPM
ALDEL
Transmission problem
2001 Dodge Dakota 6 cyl Two Wheel Drive Automatic
I would like to know what the RPM range is when the 3.9 v6 dakota shift thru it's 5-speed at each gear?
Jan 16, 2009 at 11:18 AM
  • 110,248 POSTS
Hi:
I'm not sure what you are asking. I believe red line is 5K RPM's. normal shift is around 2500 to 3000 RPM's based on your needs.
Jan 16, 2009 at 2:41 PM
ALDEL
I was asking to see if there is rpm range that the computer would know when to shift to each gear . Does the computer notifey when to shift to the next higher gear, and what rpm range for example the 4th gear, would be.
Jan 17, 2009 at 1:41 AM
  • 110,248 POSTS
Ok, now I understand. Yes the computer determines when shift's occur. The exact RPM is determined by a speed sensor, vacuum, and engine RPM. I don't have anything that would give the exact RPM.
Jan 18, 2009 at 10:54 AM
