leak around reservoir to pump?
90,000 MILES • V8 • 2WD • AUTOMATIC
SPOHNER
I replaced my power steering pump today but now have a leak. The leak is where the reservoir connects to the pump. It is a pretty steady leak. When I attached the reservoir I put in the new o-ring that came with the kit. What am I doing wrong, I only installed that one o-ring should there be another that I may have misplaced?
Feb 27, 2009 at 6:38 PM
  • 110,246 POSTS
Chances are the o-ring either moved when you replaced it or was knicked. A slight kink will cause a leak. You need to remove the o-ring and inspect it for damage and to make sure it was properly seated.
Mar 2, 2009 at 2:43 AM
  • 55,554 POSTS
Hey, I had the same problem, changed the whole pump with reservoir 3 times and still have the same problem. Checked on like and not only i need an "o" ring but also a spacer... Which I believe is making my pump to leak.
Aug 29, 2023 at 10:51 AM
