2001 Dodge Dakota Irratic Idle Speeds
RUSS JONES
  • 2001 DODGE DAKOTA
  • V8
  • 60,000 MILES
I have a 4.7L V8 that experiences irratic, fluctuating idle speeds when idling. When first started the engine can spend several seconds at approximately 2,000 rpms, then it may decrease to 1,500, 1,200 or even down to 700, then it tends to cycle up and down varing by several hundred rpms, most frequently in the range of 700-1,000.
You can even note this rpm "cycling" when in gear at a full stop. It is not noticeable at driving speeds, of course, nor does it happen all the time, however it is doing it most of the time, almost consistently when the engine is cold.
Thursday, May 7th, 2009 AT 1:04 PM
  • 109,885 POSTS
Has the check engine light come on? My guess is the TPS or IAC, but I can't be sure without a code.
Saturday, May 9th, 2009 AT 9:26 PM
RUSS JONES
No, the check engine light has not come on.
Russ
Sunday, May 10th, 2009 AT 1:56 PM
  • 109,885 POSTS
Russ:
Without a code (light) it is a guess for me from here. You need to have someone check the items I mentioned. Also, before that, take the car to a nationally recognized parts store and have them scan the computer for codes. They will say with no light it won't show any; however, I have seen situations where there were codes set that wern't noticed.
Let me know what you find.
Sunday, May 10th, 2009 AT 2:03 PM
RUSS JONES
Thanks, Joe. I'll have the computer scanned. I'll let you know.
Russ
Sunday, May 10th, 2009 AT 2:16 PM
