1996 Dodge Dakota idle problem
SLIMMER455
  • 1996 DODGE DAKOTA
  • 6 CYL
  • 4WD
  • MANUAL
  • 150,000 MILES
Hey guys I have a slight idle problem. Starts fine and idles fine but when I goose the throttle sometimes it drops in rpm and almost stalls. Do you think I could be the idle control module I cleaned I twice in the past and is the original part. The part is located on the back of throttle body has 2 bolts to hold it in and an electrical connection. Check engine light has not come on. Thanks for your time.
Sunday, February 1st, 2009 AT 3:35 PM
  • 109,885 POSTS
Hi:
Have you checked for vacuum leaks?
Sunday, February 1st, 2009 AT 6:48 PM
THETOOLMAN
  • 123 POSTS
Have you ever replaced the fuel filter?
Tuesday, February 10th, 2009 AT 9:33 PM
