Hub assembly torque specs?
190,000 MILES • 6 CYL • 2WD • AUTOMATIC
LADYBUG37
I have had problems with the bearings several times. I have replaced the HUB assembly on both sides twice. I'm needing to know what the torque should be to be sure I am doing it properly. So what should the torque be on the front driver and passenger side bolt that hold the HUB assembly on be?
Mar 21, 2010 at 3:56 AM
  • 110,246 POSTS
Install the hub/bearing into the steering knuckle and tighten the bolts to 120 ft. lbs..
Hub retainer nut to 180 ft. lbs
Mar 21, 2010 at 3:39 PM
CAPTAINWISCH
i am trying to find the correct torque spec. for front axle nut and hub/bearing assembly mounting bolts for my 2000 dodge dakota 4x4
Aug 19, 2019 at 12:12 PM (Merged)
BMRFIXIT
  • 19,053 POSTS
its 126 FT lb
CAPTAINWISCH
BMRFIXIT,
thank you for your reply. Just to clarify. The 3 bolts that hold the hub/bearing assembly to the steering knuckle are torqued to 123 ft.lbs. And the axle nut (hub nut) on the axle end gets torqued to 126 ft.lbs. Once tighten does it need to be loosen then finger tight? Thanks again i look forward to hearing back.
BMRFIXIT
  • 19,053 POSTS
axle nut is @180 3 bolts is @ 123
and thats it
do not loosen
