2001 Dodge Dakota Heater switch
133,000 MILES • V8 • 4WD • AUTOMATIC
RJSCHARRER
My heater switch has just stopped working. It works on the highest level with the blower. Is this a circuit thing or is the switch or blower need to be replaced and how much does that typically run?
Nov 19, 2009 at 2:33 AM
BLUELIGHTNIN6
  • 16,542 POSTS
if heater blower works on HIGH only then it may be a few different things. the first to check is the blower motor relay. if it is OK, next you will have to test the blower motor resistor, if it fails then it will not be able to resist voltage so blower will stay on high. if OK as well then replace the heater switch panel .
Nov 19, 2009 at 5:00 AM
