2001 Dodge Dakota Gear does not go in first/second etc
95,000 MILES • 6 CYL • 2WD • MANUAL
MUTAZ
Manual transmission will not go into any gear after the car been running for 15 minutes. When it is cold it goes in gear fine. The Master cylinder is fine but I am not sure if the problem with Slave cylinder. When the car is not running the gear go in all gears with no problem. No noise or humming noise.
Thanks
Feb 28, 2010 at 11:42 AM
  • 110,248 POSTS
When it is working, does it ever chatter when you pull out? If you shut the engine, put it in gear and hold the clutch down, will it start properly or does it act like the clutch is engaged?
Mar 15, 2010 at 1:17 AM
