2001 Dodge Dakota Front passanger window dropped, cable los
PDH027
2001 Dodge Dakota V8 Four Wheel Drive Automatic Quad Cab
Front passanger window dropped, motor working but cable is loose.
Looking for diagram to find where and how cables connect, also looking to verify if cable/pully system is okay or needs to be repaired/replaced.
Jul 25, 2009 at 3:47 PM
CEMENT HEAD
  • 38 POSTS
More than likely the pulley that broke they are made of plastic. my 2002 dakota had same problem. the part is a window regulator they run for about $150
Jul 27, 2009 at 11:15 AM
PDH027
I. Did not see any broken parts, or parts in the bottom of the door, only the cable with a nylon clip that is not connected. I wanted a diagam of the regulator and the cable routing/connections to determine the extent of the problem. Chilton, Haynes, and several other manuaals I tried provide no useful information; service manual from dodge is better, but still did not provide full diagrams.
Jul 27, 2009 at 1:35 PM
