welcome to the forum. I need a little more info. With the engine cranking, do you have spark at the plugs? If no spark, check for primary voltage at the coil and injector, engine cranking. That voltage comes from the asd relay, I'm not saying the relay is faulty, maybe some reason the computer isn't grounding the relay?
Sep 17, 2009 at 5:42 AM
