2001 Dodge Dakota dead battery, recharged, dies at 1000 rpm
2001 DODGE DAKOTA
90,000 MILES • V8 • 2WD • AUTOMATIC
PERT
left a camper shell light on and it drained the battery over two days. recharged the battery, first at 6 amp for 6 hours then 2 amp for 24 hours. started up but dies at slow idle. died as i braked and pulled into a parking space. started right up but died when i put in in gear. restarted and put into gear quickly while giving gas and drove ok. back home died again at low rpm. what's going on?
Feb 17, 2010 at 1:00 AM
  • 110,244 POSTS
Has the check engine light come on?
Feb 18, 2010 at 12:38 AM
PERT
no check engine light on. battery at 14 amps. pulled engine idle sensor full of carbon cleaned both sensor and housing. hookedup sensor to wiring and turned engine over. sensor end moved. put back together and all looks ok.
Feb 18, 2010 at 3:06 AM
