2001 Dodge Dakota Bottom of engine
SISSYHLT1
  • 2001 DODGE DAKOTA
  • 6 CYL
  • 120,000 MILES
I have just had the bottom of the engine roverhauled and it started making a slight knock in the bottom end after I replaced oil pump sendng unit and bearings what could be the problem now?
Tuesday, August 18th, 2009 AT 7:07 AM
2CARPRO JACK
  • 11,533 POSTS
That depends. Did it lose bearings (knock) before the work was done?If so the rods/crank probably should have been remachined and oversized bearings used. If it had damage and this wasnt done, it will have excessive clearances and make noise
Tuesday, August 18th, 2009 AT 8:09 AM
