My airbag light stays on all the time, and the bell dings every so often.
Sep 15, 2009 at 1:13 PM
CH112063
✓Experienced Mechanic
This means the system is disabled probably because one of the impact sensors is unplugged or the clock spring in the steering wheel is broken. Here is a wiring diagram and a guide to help you check the wiring to confirm the issue.
Test through the clockspring. Check out the diagrams (Below). Please let us know what you find. If the airbag light is on the system will not work.
Image (Click to enlarge)
Sep 16, 2009 at 10:55 AM
GORDON2464
MEMBER
You were so right on the clockspring I tested and found an open circuit once I replaced it everything started working. Cost me $78.00 I love this site.
Sep 17, 2009 at 6:28 AM
CH112063
Nice work, we are here to help, please use 2CarPros anytime.
