2001 Dodge Dakota
SEANJAMIN1
Engine Mechanical problem
2001 Dodge Dakota 6 cyl Automatic 116000 miles
my truck will drive but when i get to about 40 mph it acts as if im stomping the gas pedal but im not...the gage says like 4
Oct 27, 2009 at 1:07 PM
CH112063
  • 1,320 POSTS
If your RPM's are increasing and the gas pedal is being held steady, you should be accelerating. Is your transmission slipping? If you mean your tachometer is raising then check to see if it may need transmission fluid.
Oct 28, 2009 at 12:50 PM
