2001 Dodge Dakota
131,000 MILES • V8 • 4WD • AUTOMATIC
TAYLORWEAV
I have popped 3 codes on my truck p1784, p0733, and p0734. My truck idels wierd especially when braking and coming to a stop. The codes all have to do with my transmisssion. I was told by th local auto zone that it could possibly be my tss. Anyway i would really appreciated your advice about what you think it is and how i can fix the problem.
Thanks Taylor Weaver
Oct 20, 2009 at 10:27 AM
CH112063
  • 1,320 POSTS
It could be a sensor or the sensor could be correct. I believe with this mileage you could tell the story with your fluid.
Even if the sensor is not correct, you should not be having high idle problems that may be a slipping condition. The fluid could be low or it could be internal. I hope it is just a leak, and not inside the unit. All three codes are telling you that your engine crankshaft speed is not correct according to your transmission output speed. I would look at the condition and level, to see if it is going to be expensive.
Oct 20, 2009 at 10:42 AM
