2000 Dodge Dakota Will not start
140,000 MILES • 4 CYL • 2WD • MANUAL
RMCLUBB
truck just sputtered and stopped, and would not restart, not getting any power to coil or fuel to cylinders. Coil and fule pump only have power for a couple of seconds after turning the key on then nothing. I supect the ECM is bab but do not want to spend $300 if that is not the cause. I replaced rotor and cap with new and inspected spark plugs which were dry after repeated attempts to start the truck.
Jul 31, 2010 at 2:46 PM
  • 110,251 POSTS
Open up the wiring harness at the ECM. You will find a white wire with a red tracer. Aprox a foot down the wire is a splice. They are known for corrosion problems and shutting both fuel and spark off.
Let me know what you find.
Feb 14, 2017 at 2:29 AM
