Voltage meter works properly when truck is started cold, but if I turn the truck off after the engine is warm the voltage meter goes up to 10 volts and drops back to 8 volts and the "check Gauges" light comes on. I put a multi meter on the battery as the truck is running and it shows it is normal and not discharging.
Oct 18, 2010 at 9:26 AM
