2000 Dodge Dakota Turn Signal Intermittent
210,000 MILES • V8 • 2WD • AUTOMATIC
GMENDEZ1
Both sides, turn signal work intermittently. Sometime they work fine. Other times, will blink once or twice then turn off. I replaced the turn signal box located on the steeting column, but same results.
Apr 30, 2009 at 6:04 AM
LEGITIMATE007
  • 5,121 POSTS
your flasher fuse is probably getting ready to burn out, i would replace it and check bulbs.
Apr 30, 2009 at 8:16 AM
