2000 Dodge Dakota troubleshooting
106,000 MILES • 6 CYL • 2WD • AUTOMATIC
NINERS4ME
My passenger side window switch stopped working,it will not work from the driversi switch panel either.also at the same time the door lock on the passenger side is not working either.I can unlock from the driverside panel,but will not lock from either.I can unlock both with the keyless entry pad.Any ideas???
Mar 24, 2009 at 7:15 PM
BMRFIXIT
  • 19,053 POSTS
Check and suspect window motor
have to remove Pass side switch and check wiring most likely u have a short in the wiring harness
Mar 25, 2009 at 11:31 PM
